Crude oil tank over old concrete foundation
Dear all,
In my work, there is a crude oil tank with 10000m3 capacity is needed to be replaced with the same dimensions and capacity take, can we use the foundation of the old tank?
I remember somewhere I read that using old foundations is prohibited, as well as any equipment that had to be replace the foundation is neede to be demolished and replace but unfortunately i cannt remember where I read this
I want a standards or specifications (API, ACI,... etc) about using old foundation in crude oil industry
Best regards
Best regards
RE: Crude oil tank over old concrete foundation
I don't think there is any "prohibition" which implies legislation, but it doesn't seem like a good idea unless you still have all the calculations for the foundations and the foundations themselves need to be checked for any settlement.
There is a lot of leeway for engineering judgement here, but you need to check your own company procedures and philosophies on reuse of things like foundations or the client if you're building it for someone else.
Most standards tell you how to do something, they don't list all the things that you can't or shouldn't do, so proving a negative sometimes gets quite difficult.
For the cost difference I would dig it up and renew it myself, but that's up to you. Your risk is foundation failure once you've built your tank. No one will thank you at that point for saving 5% of the cost of the tank if it needs to be torn down and re-built.
MJCronin
Sr. Process Engineer
You may not be able to do inspection until the old tank is removed then it might cause issues if you then decide to build a new foundation.
I am very thankful for your help
Best regards
