Piping Accessory / Instrument 1
agnes.jurati
Chemical
Dec 26, 2022
1
Friends,
Does anyone know what the black accessory sticking out of the piping is?
Agnes, did you do a “Google Lens” search with a high resolution, close-up picture? I tried using the website image, but had no luck. I could not read the writing because it got blurry when I expanded the picture.
Btw, idk what it is. Best guess is it’s part of electrical heat trace system.
Good Luck,
Latexman
Try to use the information written on the equipment (sticker/label). A google search should be the ultimate resource.
My 2 cents
Pierre
heat trace indicator (bulb on top) & controller.
