cooling process inside jacket tank
charls1
ID
Hi guys,
When we have volume of the tank capacity of 1500 kg and used for the cooling process, the product temperature in the tank is 85 oC and will be cooled by cooling water which is passed through the tank jacket with the final product temperature being 45 oC (cooling water flow 15 M3/hour). If the volume capacity of the cooling water in the jacketing tank is 400 liters, how we calculate energy needed to cool the product from 85 oC to 45 oC and time taken to cool the product from 85 oC to 45 oC?
Need advise on this
best regards,charls
Hi Pierre,
Thanks a lot.
The calculation is not so simple as we learned as a student.
attached cooling tank with conventional jacketing type.
guys, need advise how to calculate
best regards,charls
 https://files.engineering.com/getfile.aspx?folder=fd3fdcfe-1fe9-43f8-8df7-ad51e713c330&file=diamter_.jpg
Thanks Pierre
Charles
