Does UV light in the HVAC system kill helpful bacteria? Any studies on this?
A cursory search doesn't come up with much. Just curious if any damage can be done by going too far on the air purification.
RE: Does UV light in the HVAC system kill helpful bacteria? Any studies on this?
That said, UV death for bacteria requires a certain exposure time, and it's unlikely that any bacteria flying around in your airstream will get killed by a single light. Bacteria on surfaces exposed to the UV light most likely will get killed, but if they're stuck on a surface, then they're not likely to harm you anyway.
On the third hand, what good bacteria are you expecting to be flying around in your HVAC?
TTFN (ta ta for now)
https://www.eng-tips.com/viewthread.cfm?qid=466759
Basically it is possible but not practical as you need 40 to 50 seconds exposure to UV-C light.
HEPA filters are much better.
I am unsure of studies about helpful bacteria that are airborne. Gut bacteria for sure but nothing for lungs.
There are no air-borne bacteria the human body needs (is in symbiosis with). So this is a moot request. There also is no selective killing method. I suspect larger bacteria with more robust skin will take more exposure to kill than others... but there is no correlation of the one being bad or good for humans. If air is a concern, you want to totally kill as much as possible.
I thought about that, but I think it was more complicated than that, i.e., it wasn't just "moisture," but actually standing water. Moreover, there' must also have been sufficient nutrients for the bacteria to multiply. If such a situation exists, then a UV system would be effective, but one can't economically line an entire HVAC system with UV lights, on the off-chance there's a pocket of Legionnaire's bacteria lurking in one's HVAC.
UV only works in the area that is radiated. It doesn't have a residual disinfecting properties like ozone or other ionizing methods would have. So even if that damper story is true, it only could work with UV if the UV shines on the damper (ideally both faces, but there may be some reflection).
UV also is an energy hog and maintenance hassle. So yo may spend a lot of $ for not much outcome. You also need safety devices that shut off the UV BEFORE a door is opened. Those UV tubes are very harsh on eyes.
By the time the virus goes from one room (via return air) through the AHU to other rooms, it is too diluted to still be a concern (at least compared to other pathways). If you really are concerned like in a lab or hospital, you just don't recirculate air from one room to the next room to begin with.
That UV sanitizing was done to give people (that don't know science) a piece of mind. And it was clear from the beginning this was an airborne disease. So all the grocery washing exercises were pointless as well and was known to be so. Just because people today still wear a mask outside when no one is around, doesn't mean there was ever a scientific reason to do so.
That was not 100% true; there was still concern about touch transmission.
And where in this thread is there wrong information?
And the fact that UV doesn't have a residual disinfecting value was maybe known.. .. since UV was discovered. It is light, why would people think it disinfects after air or surfaces are not exposed anymore?
Who here said anything like that? Attached is medRxiv preprint from March of 2020, which is when COVID was declared to be a pandemic in the US, and obviously, scientists, who apparently weren't as smart as your ASHRAE members, were diligently studying touch transmission.
https://files.engineering.com/getfile.aspx?folder=...
And if you UV a space, then let people back in (and turn the UV off), the people still will infect each other via airborne particles. No surface treatment or treatment in air handler will prevent that.
That UV idea almost sounds like the former president's idea of exposing humans to UV or ingesting disinfectants to kill COVID.
Nor is licking the transmission path for flu or colds, and yet, touch transmission can occur with both, since people touch surface and then touch their faces or eyes or noses.
No one is disputing UV can work. But you would have to apply it in the space where humans can infect each other while those humans are in that space. That likely is more harmful than the actual virus.
Using UV in the space only before humans enter will not do anything. Same for applying UV in the AHU.
You would basicaly create a huge tanning box. Possible? Yes. But not practical or healthy.
The number experts" that I met with that were trying to sell us the most absurd "solutions" to Covid and that went out almost tail between the legs when I dismantled their half truths and outright lies and misconceptions made the entire Covid experience much more bearable.
