Oilite cooling pad to Max temp rotation disk?
Maengines
Industrial
CA
Hi
I have a cooling pad that is cooled by an oil circuit, The pad max temp get to180F
The contact of the pad is by a rotating disk ho is chromed and grind 32Ra that is at 700F, will the surface of the oilite pad will be damaged?
