Venturi Pump Design
H-ENG
AU
Looking to find some literature regarding venturi pump design.
Could be website, textbook, papers or ansi/iso standards recommendations.
I've only had a quick look around but thought if I might find an expert on here.
I'm hoping to create a basic xls. spreadsheet where I can design on the go.
Much Appreciated.
I was involved in a ejector design 50 years ago without the benefit any any data what so ever, it was all done from first principles, today you are lucky as there is more than enough data available at the touch of a few keyboard strokes - do some research or buy something off the shelf and model what you need from there.
It would also help if you gave a bit more detail, maybe a member has got something suitable to suit your needs.
If you search on this site (top right corner) you can find a lot.
Based on this post I think you might be looking for something that only exists in the hands of manufacturers.
Yes, venturi pump design is done by the manufacturer. I have assumed that they developed the eductor curves were developed based on empirical observations. If you go to the manufacturer's websites, you can probably develop a spreadsheet off the published data.
S&K
Ejector selection and motive gas requirement is discussed on page 10-56 in the 7th edition of Perry Chem Engg Handbook.
