Kiribanda
- May 6, 2003
- 704
Hello members,
It is an industry practice to separate two ground rods by 2 times the rod length
so that one is not influenced by the other. Similarly, to mitigate the transfer of GPR
as a transferred potential from SUB A to SUB B, instead of sharing a single ground grid for
both subs, is it acceptable to install two individual ground grids for SUB A & B separated by
minimum of 100m so that one grid is not influenced by the other?
Is there any any code or standard recommendation
