Aluminium Floating Roofs for crude oil storage 2
Sundar S
IN
Hi people,
Good day!
I need a clarification on storage of Crude oil with Aluminium IFRs.
Understand that crude oil can be stored in an Aluminium IFR tank. However, I wanted to know whether the sulfur content in the crude will damage or corrode the aluminium parts?
Sulfur Content for the specific crude that will be stored is 1200 to 2300 ppm
Kindly share your views and feedback please.
Thank you all in advance.
I've seen may aluminum IFRs in crude oil service, they seem to do quite well in general.
Some crude oils have a high wax content which can become a problem at the tank shell, insulation and heating helps and wax scrapers can be used but for this type of crude steel floating roofs seem to be used. Sulfuric acid can be the result of sulfur combining with oxygen and water so you may have better success with aluminum full-contact floating roofs. Aggressive mixers can damage any floating roof but lightweight ones are more sensitive than heavier ones. If air spargers are used fir mixing, the floating roof needs more vents. Extremely viscous crudee oils may build up on the underside of the floating roof or the tank shell, steel floating roofs may survive this better in the long term. If your crude oil varies a lot, and you don't need a floating roof some of the time (if there are little or no light ends to evaporate and pollute the air), a chain or cable suspended aluminum floating roof can be pinned up near the top of the tank (during the last filling event) to be out of the way and then changed back to floating when the tank is next filled with lighter crude.
You won't get better than IFRS.
Normally it's sulphur in water, but that will hopefully sink to the bottom or Sulphate reducing Bacteria, but again - you really need a water phase for that so I hope your floor and walls are well coated.
Hi IFRs,
Thanks for your valuable feedback
Hi Little Inch,
Thanks for your response, Yes the walls and floor are coated
It should also be concerned that whether the alum roof is joint by adhesives. Adhesives might be eroded by petrochemicals, which affects the durability of alum roof.
