Wanna_be_SE
Good evening,
I'm new to bridge design and have begun my first calcs for "somewhat" doing a load rating for some bridge repairs. My short career thus far has been just over 3 yrs in steel design, but primarily doing stress analysis for various structures (in a shipyard), and so I wasn't using industry standards until this past May when I decided to change career paths (within engineering) and go a civil-structural route. So now I'm doing deep dives into various code requirements trying to understand why some requirements are the way they are. AISC requirements are very similar to what I was doing at previous employer, but seems AASHTO has put their spice on many different requirements (at least the ones I've come across so far). Many similarities between AISC and AASHTO, but nonetheless definitely different.
So, I noticed the AASHTO spec only considers the steel section properties for bridge beams (girders? - I typically associate girders as a member supporting other members like joists, etc but seems various terminology is used across the board), when calculating section properties (section 6). I see there's a Kg which I guess accounts for the stiffness of deck slab (which looks like a modified version of the parallel axis theorem), but it occurred to me that given the composite section and assuming in reality the neutral axis shifts towards top flange of steel beam (probably right around the top flange), then your positive moment capacity for that beam goes DOWN, given the "c" distance to outer fiber goes up.
So, how does AASHTO account for the "true" flexural capacity by only considering the steel section properties. I did take a bridge design course in college and I know there's methods for taking an effective section of concrete deck and transforming it into an effective "block" but thought it was interesting how AASHTO (at least in the section 6 I was navigating) does these calculations and would like some greater insight into where/how the equations were derived. Do the equations account for all this in some way, or is that what the Kg factor is doing (even though it's not exactly how the parallel axis theorem works, right?)?
Any insight would be greatly appreciated.
