Galvanic corrosion in air
Are there any resources / standards that provide clear recommendation on which situations (which environments, how dissimilar the metals, practical mitigation methods) for galvanic corrosion in air? (It seems that salty, humid air is the major use case).
Thanks, David
Thanks, David
RE: Galvanic corrosion in air
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
The US Navy publishes guides on coastal structures.
Just remember, if it is dry it will not corrode.
And you have to think about inside the building also hen there is a chance for condensation.
The environment is salty coastal humid air. The equipment won't be subjected to salty mist but I do imagine a bit of salt could accumulate and condensation could make it salt water. These parts will be protected by solid (not perforated) brass machinery guards, which should help. It's a guess how all of that will add up to whether it lasts 20 years as required.
I did find some info from the Navy but not an ideal source - if you have a specific reference in mind I'd appreciate it.
You could look at the multi-layer Zn rich coating systems.
Or a sprayed Al system with a seal coat.
We might propose converting this shaft to 316L S/S but adding "another" material to the question might backfire. (It appears that 316L is similar to 2205 in galvanic potential but I don't have firm data yet)
Like all plating there will be pinholes and cracks.
You can bake EN after plating and it gets harder.
How much depends on the phosphorus content.
If it is being put onto steel it should be baked anyway for hydrogen control.
If this shaft sees much load the very low strength of 316 would be an issue.
