PWHT Time Calculation
nabeel3
SA
A Half inch thick plate is to be PWTH ed. The rate of heating and cooling shall be at a pace of 500 degrees F per hour per inch.What is the total time required for PWHT, if the material is heated from 600 degrees to 1350 degrees F , soak for 6 hours and cool from 1350 to 600 degree .?
Code of Construction is required. You state rate of heating/cooling to be 500F/hr per inch. This would mean 1000F/hr for 1/2". I know of no Construction Codes that will allow this much heating/cooling...maybe the farm code.
Sounds like an exam question to me...
Mike
Dear David and SnTman
This was an exam question. If the heating rate is 500 degrees per hour per inch, how much time required for half inch.
39 min + 6 hrs + 39 min
DHURJATI SEN
Kolkata, India
Dear
Can anyone tell what is the time required for half inch plate to heat 250F is the heat of rating is 500F per hour per inch
