Bracing restraint in SPACEGASS
JSuberi
Hello
While designing a steel frame with a bracing and a horizontal load acting on the frame, how do I input the restraint for bracing in SPACE GASS. Even if the has hinge connection, will it be FFFFFF, since it can't rotate in any directions?
I have never used SpaceGass, and further I don't know whether your FFFFFF terminology stands for 6[ ]x[ ]Fixed or 6[ ]x[ ]Free.[ ] However as a general rule in a three-dimensional frame analysis all six of the member end translational fixities for a "bracing member" would all be fixed (three translational degrees of freedom at each end), and five of the six member end rotational degrees of freedom would be free.[ ] The single rotational degree of freedom that needs to be fixed is one (and only one) of the two DOF's that represent rotation about the member's longitudinal axis.
Thank you for your recommendations, now they are also interested in this topic.
