problem: How can I configure Autodesk Inventor Associative Interface?
andradesilva
Materials
Jun 20, 2017
125
In CAD configuration manager, in ANSYS 2021 R2, I can't configure Autodesk Inventor Associative Interface, just the reader. I can import .ipt files, from inventor, but I can't read parameters. Is it a limitation of the reader? If yes, how can I solve the problem and setup Autodesk Inventor Associative Interface?
Best regards,
Hi, you have take a look at Ansys platform support. There is a PDF file named CAD Support. You probably have wrong combination of Ansys version and Invetor version or you license does not support it.
