Elastic Settlement Analysis of a MSE Wall
learning2geotech
41
If I have a reinforced modular block wall, with up to 30 feet of new fill behind it and the subgrade consist of loose silty sand, how do I calculate the settlement of the wall system (including the reinforced zone)? The wall system would look like an up-side-down trapezoid but one of the short sides is squared (see attached). I've seen NAVFAC elastic settlement analysis of embankment but not sure if I can use that method here.
The internal settlement of the wall itself is somewhat irrelevant. The wall will settle as filling is progressed. You could typically assume a percentage of the wall height 1-2% maybe.
Its the settlement of the material beneath the MSE wall that is the main concern. Conservatively you could just assume the wall as a foundation sitting directly on the subgrade and apply the fill height as a pressure beneath the foundation.
Any elastic method such as schmertmann etc can be used. I have not checked the NAVAC embankment approach but I would assume its fairly spot on. Navac is a good reference.
