Top Fuel
Top Fuel
Top fuel dragster engines, any idea what maximum cylinder pressures they run at?
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Top Fuel
RE: Top Fuel
Has anyone ever seen or heard of in-cylinder high speed pressure data (such as Kistler probe data) for high power diesel engines (such as a tractor pull engine)?
https://www.kistler.com/en/solutions/research-and-...
RE: Top Fuel
This page says 6,000 psi for top fuel. Link
je suis charlie
RE: Top Fuel
I'm thinking this maybe better?
https://tfxengine.com/
And best of all it doesn't put up a cookie box.
I wish I could use some Ideas I have for the tractor pull engine crowd.
RE: Top Fuel
RE: Top Fuel
When your cylinder heads, pistons, and rods all have a 15sec service life then 10,000HP sounds realistic.
RE: Top Fuel
RE: Top Fuel
It is common for pistons, rods, valves, springs, and keepers to see some of them damaged after one run.
You just hope that they don't actually fail.
The block and crank are the big ticket items.
RE: Top Fuel
Incipient knock would get above that 100-200 psi. While calibrating, I once saw knock peak at 3000psi
RE: Top Fuel
