Help with 30 second loop timer using 4026 and 555 7 segment cathode, non-arduino
DuskyDarko
Student
PH
Can anyone help with my 30 second loop automatic count-up timer problem with IC 555 and 4026 with 7segment cathode not automatically counting? So far it still needs to be manually pressed from button to register a number going up to 99. Any help would be appreciated.
 https://files.engineering.com/getfile.aspx?folder=d60c57c5-1232-42d2-8360-2af06c898a08&file=291931115_2594394864028782_3183394919035724745_n.jpg
Did you first connect the 555 to blink a single LED, not connected to other circuitry? Start with getting the timer to operate.
Did you bother to create a schematic? Did you expect someone to reverse engineer your breadboard to figure out that your circuit is not correctly wired?
TTFN (ta ta for now)
