Contact US
Wear of rubber tire on pvc pipe
As a project I'm making a robot that travels inside of a PVC pipe track (kind of a reverse train track). It has rubber wheels and weighs approximately 10 kg. I want to look into the long-term wear of the rubber wheels on the PVC pipe but in school we didn't learn much about wear beyond the very, very basics that you'd find in Shigley's. Could anyone point me in the right direction in terms of resources to start attacking this? There are a lot of sources online about the tires themselves wearing, and a lot about fluids wearing PVC pipe, but not about tires wearing the substrate itself. I was thinking of making a spreadsheet with some different parameters to try out instead of making a simulation because I want to learn it a bit more thoroughly.
Thank you!
-Shea
RE: Wear of rubber tire on pvc pipe
@moon161 sounds good, will do!
Also add a sketch?
A tyre inside a circular pipe? Are you mad?
1) Tribology (the science of wear and friction) can be wildly complex. It's often built empirically and to be honest I doubt there is any empirical data for a small tire running against PVC.
2) Knowing what I know about tires generally, there is flex in the tire as it rolls under load. The less flex, the longer it will wear. It is possible to select the tire and design the contacting surface so that the friction (and wear) are minimized. You don't want to twist the tire, for example.
3) Low-cost tires always have an age limit. Trailer tires for example have a shelf life whether they're in use or not and weaken with time, perhaps even moreso than usage.
4) If you're being challenged to predict the wear life of this tire support system, I wish you good luck. See item 1. Most things in real life cannot be accurately predicted using engineering methods. Perhaps you can run an accelerated-life experiment or pattern this after a real-world example that has well-understood life.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
