Lightbulb choosing circuit
Cigjonser
Computer
I apologize in advance if this is not the place for this question. I have zero experience with circuits and don't even know what terms to search for.
I have a bug zapper that takes two bulbs and when the switch is turned on, both of the bulbs turn on. It is not necessary to have both on at the same time though, as one bulb is bright enough to attract flies and other winged nuisances. Those bulbs can be expensive so since one is good enough, I only use one at a time. It would be nice to have that second bulb as a backup though. That way there is no downtime when a bulb burns out.
Is there a simple circuit that exists that can do this:
[ul]
[li]If both bulbs work, power bulb 1[/li]
[li]If bulb 1 is burned out, power bulb 2[/li]
[li]If bulb 2 is burned out, power bulb 1[/li]
[/ul]
It would be a bonus if there was an indicator that showed whether bulb 2 was burned out or not, but that might be outside the realm of "simple" and anything outside of simple might get too expensive to be worth it, I'm not sure. Or maybe there is an even better alternative that I haven't thought of.
How much are you willing to spend? I'll take a wild guess that the simplest real solution will cost about half of what the bug zapper cost.
TTFN (ta ta for now)
Put a dusk-to-dawn controller on the second bulb with the detector aimed at the first bulb.
Add a single-pole double-throw switch ahead of the bulbs that directs the power to either one bulb or the other. Simple, not too expensive.
CR
Can you just disconnect the second bulb? Cost is nothing if it works.
Power the 2nd lamp through an normally-closed contact of a relay, power the relay coil from a current switch sensing the 1st lamp. When the 1st lamp is running the current switch is closed, powering the relay and opening the NC contact. When the 1st lamp burns out the current switch opens, closing the NC contact and thusly turning on the 2nd lamp.
EDIT: I just realized if you could get a normally-closed current switch you could eliminate the relay. Not sure how common those are though.
I like this last one better than mine . . . the OP would have to mark the outside of the unit, though, to denote the bulbs as one and two since the condition
would not be met.
Nevertheless, minor detail.
CR
Thanks for everyone's replies. I appreciate your time. I'll try the relay option and see how it goes.
