Use of over-sized VFD
Freshsurfer
41
Hi!
I'm working on a application of a VFD for a motor of 40hp @ 440Vac. The client has a 211 amper capacity VFD.
Can I use it for a 40hp (50A) 440Vac motor?
Is probably to have some Harmonics issues due that high of over-size?
It might work. The VFD itself would have no difference in harmonics. If you are also filtering then maybe.
