PATRAN stuck while read MASTER file
Hello Everyone!
I'm prety new with NASTRAN and PATRAN pre/post-processor and I runed into an issue while i try to attach the MASTER and .op2 file of the results. I have to run an analysis with SOL 400 but when I try to attach the MASTER file the black cmd window of NASTRAN pop-up and it doesn't do anything. If I request an .op2 file as an output the attachment is not problem, but when I try to make a quick plot about the deformed results the PATRAN instantly quit. Have you ever run into this? What was the problem and the solution? Thank you for your response and help!
