Need help in finding out X-Y co-ordinates of an image.
DesEngineer4
IN
I'm working on a project, my objective was to find the X-Y Maximum & X-Y Minimum coordinates. I have taken an image as attached (Input_image) and prepared some python code(attached as Python Code), I'm getting too many coordinates (attached as results). I need only 4 coordinates of an image as marked in yellow in the attached required coordinates. Please review my code and kindly help me with the solution. Thank you for your time and support.
Thanks & Regards,
Sam
 https://files.engineering.com/getfile.aspx?folder=182dd450-6d94-4086-9f45-7914aba88a87&file=Image_processing.zip
Is "input_image.jpg" supposed to be "coordinate8.jpg"? You've not included the very image that the program is supposed to read. Your comments are confusing; you state that "Create mask of all pixels lower than threshold level" yet your code appears to set the mask to be > threshold.
TTFN (ta ta for now)
You need to start by clearly stating what you expect to accomplish; your post and code are inconsistent with what you seem to be wanting
Seems to me you're looking for to max and min points in each direction or perhaps the points halfway along each edge of a bounding box
This seems like a simple step following on from determining the perimeter which is your too many results. A simple for loop to find max/min x or y? Maybe I'm missing something as your explanation is not that clear though, and the solution seems fairly obvious given the results.jpg image?
