IS circuit means that the Entity parameters (L/C) of the load (Transmitter) is lower than that of the barrier. So no chance of sparking due to hot working or Shorting. Technically, even the cable's entity parameter has to be considered for the length between the marshaling cabinet and the transmitter. Only L/C are considered since R does not store energy. Each loop will have to be checked individually even for same transmitter/barrier combination but for different cable length.
