pipe flange thickness calculation
I want to make a drawing for pipe flange (slip-on type). Details as follows:
Pressure: PN16 Bar
Material: Mild steel
Doubt: What thickness I need to give for this flange? Since this is a very big size, most of the standards have not mentioned about the thickness value.
(Note: Regarding flange drilling details, I can refer to the valve drawing)
Please share if you have any calculation sheet for this requirement.
Thanks in Advance.
Pressure: PN16 Bar
Thanks in Advance.
RE: pipe flange thickness calculation
MJCronin
Sr. Process Engineer
