Dynamic pile load test followed by Static load test
Geosubhtech
Geotechnical
Jan 2, 2018
57
Greetings to all,
I have a query about load testing. Is it correct to conduct a static pile load test on a pile which is already tested by dynamic load test. The final settlement attained is 0.1, 0.3 and 0.86mm in the three successive blows. The pile is a bored cast in situ pile.
If anyone conducted static load test after dynamic load test or aware of any reference or manual or codes kindly share.
Thank you for taking your time.
Shubh
