ETABS Semirigid Diaphragm No Axial Loads on Braced Frame Beams
justanormalguy
Hello All,
I am new to Etabs coming from RAM SS and am modeling a building laterally supported by braced frames. I have modeled the diaphragm as semi rigid but the beams on the braced frames are seeing zero axial force. I have tried to assign a semirigid diaphragm to the deck, also by going to assign/joint/diaphragms and nothing really changes.. Has anyone had this issue before?
Thanks!
What have you modelled the slab as? Shell or membrane?
Try modelling it as a normal slab shell with reduced bending stiffness.
