Clamp load hole stress
I've modeled a rectangular tube being clamped via a pretensioned bolt:
The tube is 10 mm thick (steel) and is fixed at one end. The pretension force is 50 kN.
I also modeled a 50 kN nodally-distributed force on the washers of another connection, to compare the results:
The contacts between the components are set to "friction" with a coefficient of 0.7:
The simulation is a non-linear static analysis.
The stress results are very large. Especially around the hole edge:
I realize that 660 MPa is an overestimation as the stress is beyond the yield stress. But these results suggest yielding around the hole.
Additionally, the deformation results show a deformation of 0.2 mm at the hole edge:
However, just from experience/intuition, it is obvious that torquing a bolt to spec (50 kN clamp load) will not cause a 10 mm thick tube to yield.
I had a test done. After torquing the bolt 50 kN, the bolt deflected 0.1 mm (not 0.2 mm as predicted by the simulation). Upon release, the tube sprang back with no evidence of plastic deformation.
Why are the simulation results much larger than reality?
How should I accurately simulate this configuration?
RE: Clamp load hole stress
The nonlinear analysis is to allow for changing contact status. If I set a frozen/bonded contact between the components, I get additional stress concentrations (not extreme) at the borders of the contacts and lower overall stresses which I think are a result of artificially forcing the load to distribute evenly over the contact area.
The 1D elements on the washers are RBE2 elements but the 1d elements in the other components are RBE3 elements.
You have no information at all about post-yield behavior if you run analyses with linear elastic material properties.
"I'm saying that the current results that are showing yield seem way too high, especially since the physical test shows a much smaller deformation and no signs of plastic deformation."
The test shows 50% of the deformation, according to your post, but you did not specify the accuracy of your experiment. A deflection gauge will not be able to provide you with good accuracy, and the uniaxial deflection measurement cannot be tied to an analytical formula that will give an accurate cross-check of the FEM calculation. In short, your experimental setup is not suitable.
You need to use digital image correlation or a similar technique to record strains (to be compared to calculated strains) experimentally.
PS. You have used very few elements and also displayed stresses and deflections averaged from multiple neighboring elements. The solution to this problem is very sensitive to the assumptions made at every step of the way, unlike e.g., simple beam bending, so I would suggest mesh refinement, ditching the obviously severe averaging technique in post-processing, using a plastic material model (or re-defining plate thicknesses until only very few areas are stressed beyond yield), and ensuring that you are not connecting rigid links to shells - those screw up calculations more than anything else.
