Difference Reduced Bore and Full Bore
dear all,
I kindly request to all the specialyst, which are the process requirement in order to choose a REDUCING BORE or FULL BORE.
When I choose one respect the other.
Thanks and best Regards
Marcello
Marcello
RE: Difference Reduced Bore and Full Bore
Even so, more detail in your question will give you better answers. In basic terms, a reduced bore valve or flow meter will have better control or metering response at low flow rates, but limits the maximum flow rate.
The is an increased pressure drop compared to full bore but this is usually negligible.
