Greetings,
Once again, I am posting for a problem at one of our floating roof tanks used for crude oil storage.
After a routine trial by our fire safety to check the functionality of the tank fire fighting system, we noticed that the water used for the drill accumulated on the roof and stayed for days and drained very slowly although all the drain valves at the tank bottom were opened.
The obvious issue was with the articulated draining systems, so what do you recommend in this case? and is there any chance to try any solution while the tank is in service, like blowing the roof drains by high pressure water or steam?
Thanks and best regards,
