Design of pile strip footing
I'm not familiar with design of piled strip footings.
Is there a reference you recommend as a guide.
Unsure if the continuous beam is supposed to allow for support from ground, or span between piles.
I don't have the geotechnical information, and presume insitu ground will be swapped out with sand fill locally.
RE: Design of pile strip footing
Reason I asked is that a while ago, I got the impression that rails (for trains) may have been designed as: Supported on sleepers, in combination with the ground.
