Allowable foundation settlement - portal crane
Has anyone seen a specification for allowable settlement of foundations for a traveling portal crane.
Is there a general allowance or does it depend on each portal crane specifically.
The size of the crane is somewhere between 100t to 500t.
There is a strip footing along each track. I'm not sure if piling is normally required. Ground locally, will consist of imported sand fill most likely.
RE: Allowable foundation settlement - portal crane
We don't have a manufacturer yet. This is still early stages.
I wouldnt be making any guesses. Id let your client advise what to adopt at these preliminary stages.
I was aware it has something to do with travelling, and how much incline the motors can overcome.
But we don't have a specification though.
So likely less than that
just call me Lo.
https://www.aisc.org/globalassets/modern-steel/ste...
These cranes are sensitive to any deflection (including settlement) and this is a good question to ask early.
just call me Lo.
The attached document from Retrograde is quite useful.
Sorry to have missed that line. The idea of "mat foundation" is based on the notion that it is a better approach to overcome complications due to differential settlement. And, at the preliminary stage, with the worst-case scenario, any change thereafter is likely to bring down the cost rather than escalation.
@mte12,
If footing is already in place, how do you install piles?
So installation is future.
