Flatland Detention
Flatland Detention
I've got a subdivision
I can dig down deeper and have a pond. But the problem is that we have no electricity. Nothing will be put in until housing starts. But we need the subdivision approved before we can sell the lots.
Is there some other method that can be used in this situation?
- The drop from one side of the subdivision to the other is only about two feet.
- My calcs show that the required detention would be about 5.4 acre-ft.
- Basic math then says that I need detention to be 2.7 acres.
RE: Flatland Detention
Is infiltration not an option? Much depends on the soils and surrounding area. How deep is the groundwater table?
I don't follow the relation between having electricity and excavating a pond.
Lots of questions need to be answered on this before any helpful solutions can be offered.
I've already included the runoff coefficients in the calculations for total volume.
If we excavate further than natural grade, we'll have to install a pump to get the water out and onto the neighboring lot's entrance elevation. Pumps require electricity.
If you have 2 feet of drop across the site, why are you planning on a 2 foot deep pond? If the highest point on the project site is at elevation 2500 ft, and the lowest point is at elevation 2498 ft, the bottom of the pond would be at 2496 ft? Or are you planning the pond to have a built up containment berm with a bottom elevation of 2498 ft?
There still needs to be some slope to the outlet pipe/channel from the pond. How will the water leave the site? Will it discharge into an established system of drainage ways? Or, does it need to be discharged in a metered fashion to take an extended time to discharge onto neighboring property?
What size is this property? What is the average slope across the surface? What will the slope be after development?
Maybe sharing a diagram or plan view with elevations would help.
