I have a building where approximately 50% of the structure is rotated 15 degrees.
I am using a response spectrum analysis in accordance with the National Building Code of Canada 2015.
The building is a structural steel, braced frame building.
Normally I would calculate the base shear using the static code method, then scale my RSA accordingly to be under the 2/3 cutoff, or 80% of the code base static shear, whichever is higher.
Due to the non-orthogonal layout, by base shear has an X and Y component for each response. To combat this, the code recommends that you lock the model to only allow X movement for the X base shear, and Y movement for the Y base shear. Then take the period and base shear from each locked model. We then determine the scaling factor and apply it to the main model.
This works fine, however i do have concerns.
For my locked model, i have a period of about 0.23 seconds in each direction. Code calculated period is 0.16 seconds. Great. I determine that the 2/3 cutoff applies and scale my response to 90% in my main model with both degrees of freedom active. (Note that i am still combining 30% of my X response with 100% of my Y response, and visa versa.)
Now here's the concern. When unlocked, my response in the x direction has a period of 0.37 seconds, and my Y response is 0.27 seconds.
Am I being unconservative by scaling down by 0.37 second response to 90%, and applying the 2/3 cutoff rule found in the Canadian code. Or is this the right approach?
