API 650 -tank's internal pressure
hi everyone
can anyone please help me to calculate the tank's internal design pressure
i've foun this formula : p=8*A*Fty*tan(10)/sfD*2
but the problem is about the A : the area resisting the compressive force as illustrated in Figure F.2
i coudn't know that area
RE: API 650 -tank's internal pressure
Also fig F2 has many different details, but no "A"
Can you define your question a bit more please.
thanks for responding
my tank is with a conic roof and a central column
with H=8m and D= 9.67m
i want to calculate the internal pressure of the tank and i found in the AL.12.2 of api 650 this formula : p=(8A*fty*tan(teta)/(sf*d^2))+RhTh
the problem is :
A:is the area resisting the compressive force as illustrated in Figure F.2 except that 16t shall be replaced by
56ts Fty
first of all i want to know if this rule is the correct one to use in order to calculate the internal pressure,
if it's right then i wanna know the area resisting the compressive force
btw i've opened figure F.2 but it's not clear for me
thank in advance
Anyway area A is the hatched area as described in section F3 is my reading of the code.
Normally you would use the calculation and procedure in section F.
But if this is an existing tank it will state the design pressure on the tank name plate or the tank drawings.
What are you trying to do exactly?
I am a student in my last university class and i have to end it with a project
And mine is : conception of a tank for liquid sulfur following the api 650 instructions
My tank's material is acier s355
Thank you
API 650 isn't great for tanks with internal pressure.
Liquid sulfur tanks will fall under Annex M due to temperature requirements.
The specific gravity of liquid sulfur is greater than 1, so include the extra for that.
Usually, liquid sulfur tanks will include a hefty corrosion allowance as well, 1/8" or 3mm or more.
If the required internal pressure exceeds the weight of the roof plates, it will fall under Annex F as well.
If the tank is more than around 12m diameter, it will likely have a supported cone roof with rafters and center column. Under that, a self-supporting roof, either cone or umbrella.
The diameter is 9.67m but with supported cone roof and a center column
The API-650 code is not appropriate for this high temperature, high density, corrosive service
The Young Original Poster is being set up as the Engineer of Blame (EOB) for this MBA fever dream ....
MJCronin
Sr. Process Engineer
