weldability of 10705BU-ST which is equivalent to AISI 422, ASTM A565 Gr 616
I'm looking to weld build up (add about 0.5mm) to a spacer key made of 10705BU-ST material (AISI 422 or ASTM A565 Grade 616). Can anyone provide guidance? the application is LP steam turbine and the key face is about 4.5" x 2" in size. I plan on just having two strips welded on to the face to bring the key into spec, not weld the entire face.
Please advise, urgent
RE: weldability of 10705BU-ST which is equivalent to AISI 422, ASTM A565 Gr 616
thank you!! this thread you pointed to answers my question
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
