tmgczb
- May 12, 2021
- 175
Does square groove mean no groove?It is said that the maximum thickness of plate applicable to square groove is 10mm.
Kindly please experts here advise.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I'm assuming this is a reference to a prequalified weld per AWS D1.1tmgczb said:It is said that the maximum thickness of plate applicable to square groove is 10mm.
I suppose there are also some other factors that matter, like welding process and material...tmgczb said:It is said that the maximum thickness of plate applicable to square groove is 10mm.
