How to make two elements strike each other in ABAQUS?
I have modelled a Beam and Car using Abaqus for impact analysis. During the analysis, the Car passes through (Penetrates) the beam without any impact. Can anyone please give me any valuable suggestions? Thanks in advance!
RE: How to make two elements strike each other in ABAQUS?
For your kind information, I have defined interactions as you mentioned. Still, there is no impact happening between the two elements. I have attached the *.cae file for your reference. Please check the files and offer your suggestions.
https://files.engineering.com/getfile.aspx?folder=...
Thanks again!
