Dimension edge from a radius
Is it correct to dimension an edge from a radius with a position tolerance on it? I want to control this edge as it sandwiches a cylindrical part. See attached photo. Thanks.
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Dimension edge from a radius
Inch dimensions do NOT use a leading zero when less than 1" is the dimension value.
See ASME Y14.5-2018 section 4.3.
Ben Loosli
What a nightmare! Even if you do everything right, nearly everyone will probably read it wrong. It would be helpful to exaggerate the non-concentricy of the arcs as much as possible.
