PSV orifice size
PSV orifice size
Hi Guys,
What will be the largest and smallest orifice size(with complete designation)?
As far as i know '1D2' will be the smallest orifice size, and '?T?' is the largest one but i don't know the highest inlet and outlet size.
Please reply.
Thank You!
Please reply.
Thank You!
RE: PSV orifice size
Outside of API-526, sizes made can range from 3/8" inlet up to 20" x 24" (in x out) depending on manufacturer, and may be limited by application.
Actual orifice can vary by manufacturer, The 20 x 24 from one maker can have an actual orifice area of approx. 138,000 mm2.
What concern do you have?
*** Per ISO-4126, the generic term
'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
Consider this handbook to support your query.
Good luck
Pierre
Thank you for sharing.
