Bystronic Handling Problem
I think you got a stuck key. it could be the extended keyboard too. disconnect the standard keyboard first, ten the machine keyboard, they're hooked up via PS2, USB or serial. hook up a standard usb keyboard via USB to test.
Chris Krug Maximum Up-time, Minimum BS
