Contact US
Hi guys Kindly explain the below
Hi guys
Kindly explain the below by examples. I didn't understand
When making root deposits only using GTAW, SMAW,
GMAW, PAW, LBW, LLBW, and SAW, or combinations of
these processes, a PQR for a process recording a test
coupon that was at least 1/2 in. (13 mm) thick may be
combined with one or more other PQRs recording
another welding process and any greater base metal
thickness.
 In this case, the process recorded on the first PQR may
be used to deposit the root layers using the process(es)
recorded on that PQR up to 2t in thickness on base
the metal of the maximum thickness qualified by the other
PQR(s) used to support the WPS.
RE: Hi guys Kindly explain the below
Search the site, this has been discussed many times.
Seems self-explanatory to me. Do you need an example?
Suggest retaining a Welding Engineer.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
