Joint Mass Effect on Modal Analysis
Hi Guys,
I am working on an elevated water tank, and I wanted to add the Vertical mass of water as a lumped mass using a joint linked to a girder surrounding the water tank. when I add a joint mass I do not notice any effect on the fundamental period of the structure (I did make sure that am using the correct units, I did it using weight and using mass values, same answer). BUT when I try to distribute the exact same mass over the length of the girder mentioned above and apply that mass as a frame line mass it has a visible effect on the fundamental period.
I tried adding the same mass as a uniform load and then adding that load as a mass source and I got the same answer as when I add the frame line mass.
am going crazy here, why is this happening. knowing that when I try and add a Horizontal joint mass I can actually see its effect on the fundamental period.
Thank you and I appreciate the help
RE: Joint Mass Effect on Modal Analysis
If you did not add horizontal mass then this would not affect the horizontal modes of the structure.
what would the modal fundamental period change drastically then when I change the type of mass applied (mass joint Vs frame liner mass) ? am still applying the same vertical mass, only using a different approach.
Thanks again, this would help me better understand what's happening.
