Risafloor creating a simple wall
Sam1993
EG
hello,
I was trying to draw a one simple wood wall on grids then I doubled click on the wall I got an error says that : wall panels must be rectangular, coplanar and no longer than .5 feet (Error code 2129)
Any solution to this problem?
RISA3D help file said:
Error 2129 : Wall panel need to be rectangular, coplanar, vertical, and at least 1.5 inches long.
A wall panel needs to be rectangular, coplanar, and vertical, as well as be at least 6" tall. The warning log should indicate which wall panel and which condition was violated. The wall panel joints must be adjusted to make it vertical, rectangular, and coplanar.
Is your wall actually rectangular, planar, vertical, >1.5" long, and >6" tall? Doublecheck the corner coordinates.
