Autocad Hydraulic symbol library
Hello to all,
I have been looking around for a library of hydraulic symbols to be used in Autocad but I could not find what I was looking for. Eaton seemed to have an AutoCAD add-on but it does not work with modern versions of ACAD.
Does anyone of you have this sort of library that would be of great help? Thanks by advance, Vincent
RE: Autocad Hydraulic symbol library
I suggest buying the ISO 1219 standard so you have the basic measurements of the symbols and then make your own symbol library in AutoCAD. Start by creating the really small basic parts, like flow arrows and symbol squares. Then you group them together to create valve symbols. Put the base point in a smart place. Be consistent with what you do. Once you built up a library it is quite fast to expand it.
I started using the part numbers in the ISO standard at first but dropped that pretty quickly, it was just a mess and didn't help me at all. Now I just go with the autogenerated block numbers which is fine, I don't use them for anything anyway.
When it comes to stuff like variable pumps, variable motors, I use the manufacturers symbol from the datasheet instead of the generic symbols from the ISO 1219. It takes a little bit of work to model up a variable pump but I'm guessing the amount of different pumps you will use is limited. Also, most of the components in a pump regulator for instance, you can pick from your own library. Same with LS-valves, I recreate the manufacturers symbol from the datasheet, making a building set out of it. Spool is one block, actuator is one block (probably same as ISO) then i build up a section like that. Then stack sections to complete valves.
