If it is a non-bearing 3 meter high concrete wall with 0.47" (20mm) rebar spaced horizontally and vertically every 8 inches (200mm) apart connected to the beam and column. Is there any guidelines about minimum thickness of the concrete wall?
Remember you can put wood or cardboard in the gap and it has no load bearing since there is beam above and below it. So what controls the thickness of the 3 meter high concrete wall? Can you just use 4 inches thick? Some precast wall are also 4" so it is the rebar reinforcement that controls the design?
