Mar 7, 2022 #1 7016 Mechanical Joined Jan 23, 2020 Messages 29 Location IN Hi, Is it okay to buy Dovetail joint gaskets for bigger sizes like 3000mm diameter? Will there be any issues in-terms of leakage at the joints? Pleas suggest with your experiences. Material: Rubber (EPDM)
Mar 8, 2022 Thread starter #2 7016 Mechanical Joined Jan 23, 2020 Messages 29 Location IN Anybody... Pls suggest with your experiences for my above post. Upvote 0 Downvote
Mar 9, 2022 #3 3DDave Aerospace Joined May 23, 2013 Messages 11,446 Location US Based on the information - yes. Or no. I'd suggest a discussion with a stress/structural engineer to determine if the joint will have enough support to provide a sufficient load to get the contact pressure you expect to resist. Upvote 0 Downvote
