There's no plug-and-play option. You could probably create yr own custom wall type that analyzes similarly to the strong-wall. Basically try to get the capacity you need, and then have the program distribute the forces based on capacity. Either way, I would be double-checking the results and maybe doing it one or two ways to check.
