Contact US
Connection region
Connection region
Connection region
Just quick question. If one alredy defined connection region which are defined by surfaces, after remeshing solid or surface where region is defined, does region update elements included in region, or is needed to again define connection region?
Grozozo.
RE: Connection region
Which software are you using?
Most of the FEA software(s) store information of elements and nodes for the surface set. But usually the information is modified when remeshing is done. Some software(s) may not modify this information. You can check this by highlighting the elements/nodes for this surface set whether they are modified or not after remeshing.
Yes, i forgot to say, i am using Femap, thank you for answer. I just needed to confirm, just to be sure. Thanks again.
Grozozo.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
