How do I solve cantilever bar made up of two materials analytically (dynamic analysis)?
mxl9549
Student
Hello Eng-Tips team,
I am trying to solve the below problem analytically
โˆ‡โˆ™ฯƒ + ๐‘_๐‘ฅ = ๐œŒ (๐œ•^2 ๐‘ข)/(๐œ•๐‘ก^2 ) --> (1) is the governing equation
[Note: In the above problem, b_x = 0 (no body forces)]
IC: u(x,0) = v(x,0) = 0
BC: u(0,t) =0; u'(x=1,t) = F(t)/(A*E2)
[Note: Since force (F(t)) is applied on bar that has modulus E2, I'm assuming the BC is F(t)/(A*E2)]].
I'm having trouble understanding how to solve the above problem.
Q1). Does interface conditions come into play in this problem? The displacements, stresses are continuous at the interface (Assuming it is perfectly bonded).
Q2). If I consider each portion of the bar individually (material1 or material2), how do the boundary conditions behave?
Any help would be much appreciated. Thank you!
Not sure what you're trying to solve for, but I can tell you this much - F(t) is constant through both sections, so the displacement of each part is (F(t)/ A*E)*L, where L is the length of the section under consideration. The total displacement is the sum of the displacements of the 2 parts. I hope that helps.
Hello BridgeSmith,
Thank you for the response. In this problem I'm solving for displacement only.
1. The blue color section is fixed at the left end. So, the BC is u1(x=0,t) = 0.
2. Now, if I consider the yellow section the left boundary is the right boundary of the blue section.
So, can we say u2(x=0.5,t) = u1(x=0.5, t)?
Note: u1 is the displacement of section 1,u2 is the displacement of section 2.
When I consider each of the above sections separately, I have a differential equation that I need to solve. (Governing equation (1) mentioned in the problem).
This governing equation could be solved if I impose 2 Initial and 2 Boundary conditions.
i.e,
For blue section:
โˆ‡โˆ™ฯƒ1 + ๐‘_๐‘ฅ = ๐œŒ1 (๐œ•^2 ๐‘ข1)/(๐œ•๐‘ก^2 ) --> (1) is the governing equation
IC: u1(x,0) = v1(x,0) = 0
BC: u1(0,t) =0; u1'(x=1,t) = ?
Note: Based of your first answer, u1'(x=0.5,t) = F(t)/(A*E1)
For yellow section:
โˆ‡โˆ™ฯƒ2 + ๐‘_๐‘ฅ = ๐œŒ2 (๐œ•^2 ๐‘ข2)/(๐œ•๐‘ก^2 ) --> (1) is the governing equation
IC: u2(x,0) = v2(x,0) = 0
BC: u2(0.5,t) =?; u2'(x=1,t) = F(t)/(A*E2)
Is this u2(0.5,t) = u1(0.5,t)?
I was majorly confused about how to handle the boundary conditions.
