micro components to drive a shaft
Hi
can anyone suggest electronic means to rotate a small shaft? it has to be less that 5 mm in scalel. shaft diameter 1.5 mm ? load a couple of grams.
many thanks
Antoine
Sunclipa
many thanks
Antoine
Sunclipa
RE: micro components to drive a shaft
TTFN (ta ta for now)
i should explain more i want it to turn to two positions at 90 degrees to one another . time 0.5 second approx between two positions. not my technical area
https://www.ebay.com/itm/324552358072?hash=item4b9...
