Stability models of rocket engines 1
Lumbisno
Aerospace
AR
Hi everyone! hope you are all doing well, I was wondering where might I find solid info of how to build a mathematical model of stability in a rocket engine (given certain known parameters).
Thank you all in advance!
Modelling combustion stability on a combustion chamber
Regards, Wil Taylor
o Trust - But Verify!
Wow, the exact same question. Are you a bot, Lumbisno?
So, 2 months later, you've made no progress? If anything, there's signs of regression, since your original question had more detail.
TTFN (ta ta for now)
Just so there is a little context, in between these two months i have been taking all the end of year exams and I am now returning to this project, did not intend this question to be interpreted the same way as my previous one, instead, i'm now looking into how to start building a good representation model of a given system, as opposed of the analythical generalisation (which is frankly impossible for my level at least) of said systems, I do want to make clear that I'm a beginner in this field and that's why maybe these questions seem weird, for the next one I intend to be more concrete, thank you all :)
